No the plasma does not shut off the torch does , maybe I’m not setting the pierce delay the correct way because I have tried .5,1, And even 1.5 all the same fault
The torch fires on first cut then jogs to next cut on same piece and the z axis jogs all the way down touching the metal and the jog doesn’t stop until I get the IHS fault and it does not fire
I had this problem, it was the female port that torch fire cable plugs into in the electronics box. Got one replaced and has been ok since. I’ve seen where other people bend the post inside the female end a tiny bit and solve this problem also but I’m sure it’s not recommended lol
So what i did to make my first cut cut was uo in the right hand corner turn off the ihs i think thats what it is! Its the second green tab beside where it says machine therss a little x that closed it and boom it cut a ready to cut file
Jog your torch down until it almost touches the metal and take a picture of the whole Z axis area. I want to make sure that your torch is mounted correctly.
