The IHC cable connections to the torch for the THC, have broken loose, and I am trying to figure out where they are suppose to be connected.
One of the wires came loose from a ring terminal connector on the back of the Z axis plate that rides on the two round rails. I seems the only way to get to it is to remove the set screws on each end of the and remove the round rails. The rails do not move easily and I am wondering how tight they might be?
The other wire, I have not clue where it connects, as there are not other unused connectors hanging around.
I believe that they close a loop when the torch touches the material, which sets the IHS, but I don’t know where or how the other wire is suppose to connect to the torch. The Plasma cutter is a Hypertherm 85 with a machine torch head.
TIA
