I have a Miller Spectrum 875 Autoline currently on a Crossfire Pro table with the regular handheld torch. I had to get a cable from miller to run the handheld torch remotely without a machine torch. Thinking about the possibility of upgrading to a Hypertherm 85 in the future. If I go the Hypertherm route, what is needed to hook up to Langmuir table as far as THC and torch firing goes. I saw Langmuir offers the adapter cable to go into a CPC port, but I do not want to use the machine torch, as that is an extra $1,000-1,200 cost vs just using the handheld. Is it possible to use the handheld torch with a Hypertherm, or would I be required to go machine torch route?
For the hypertherm sync you may have some issues.
We just recently had a topic discussing modifying the hypertherm sync and torch to work in this application.
Maybe me or somebody else will find it
Edit
