I had planned on using an PM600 machine on my Pro table. I had made all the connections to fire the torch and read arc volts and then the old style torch failed. I found a used PM800 that had the new Duramax Torch upgrade for 200.00. The machine and torch work great but it does have a buzzing main breaker I’m trying to track down a replacement for. I thought I could use the 800 torch on the 600 but the pin count is different. How do I wire the torch fire line and the arc volt for the THC on the PM800? And in case can I move som pins to make the 800 torch work on the 600
