Thinking out loud would you have to draw oversized and cut on the line to share the same line? Then you could attach them with a joining line in the corner that will pretty much be sacrificed and burn away. That would cause you to do more clean up in the end.
could something like this be used it is based on .060 kerf and has .080 gap so most if not all scrape would burn away and in theory not break the arc. sheetcam wants to treat it like a open line so correct compensation
It will certainly cut the file. It opened up as each rectangle being 4x8. The issue would be in started clockwise in the simulation then cut down the first shared line then cut counterclockwise on the on the second the clockwise back to counter.
So I am not smart enough to understand this yet (maybe never will ) but, if you can do 4, could you do as many as you wanted? maybe a row 96” long all with one pierce?
I see what you’re saying. Technically you’re doing a centerline cut not an outside cut so some of the outside pieces could be cut in the wrong direction. Good point
The dimensions might be skewed a bit off…really hard to expect “exact” copies since there are sides that are cut with left and right sides of the torch.
No lead-ins/lead-outs so there might be some divots
