How would you cut this?
The way is see any chance of doing it will certainly save time at the sacrifice of “looks”. Which doesn’t always matter. @Knick it is possibly worth a test cut. @TinWhisperer, @ChelanJim and I need to know.:thinking::smiley:
@Knick here is a double that will work with correct compensation and direction. it will have a .060 tab between them that will break apart and clean up easily.
2x3.dxf (98.0 KB)
But won’t the tab add another pierce?
Oh no it is just 2 rectangles connected at the corner they are spaced far enough apart for the kerf to fit. The tab will probably mostly melt away . It is drawn as a single profile not tabs added.
I dare say we could double this and cut 4.
I see. I was responding based on your description. I am not near my computer.
Great option: all cuts would be on the good side!
That what I figured you was away. It is certainly a option and a viable one assuming weld will consume the bur from separation. With the tab being .080 x 0.060 it should easily break if it doesn’t burn away. It will be in a corner where the torch changed direction twice.
