I’m progressing on my learning and test cuts using Fusion 360 and Firecontrol. I would like to not have the machine torch retract all the way to the top (probably 3 inches) between cuts as this greatly extends the total time if I am going to do a large piece with lots of cuts.
I’ve played around unsuccessfully with various height settings in the 2D profile “height” tab, but they do not seem to make any difference. What should I be doing to have the torch cut, then retract 1/2 inch, then cut, then retract 1/2 inch, etc?
