Hey guys been running all day and i have a few quirks that hopefully the forum can resolve, my bore toolpath and chamfer toolpath and drill toolpath all gave me this error, the first time i ran them, i could clear it and hit start again and the toolpath would run no problems.
Final issue is a clicking or knocking noise coming from the z axis when i go up and down with the z i will post a video later as I cant do it from my phone.
I can’t tell by the screen shots, but are you running in inch or mm?
The X value of 33.296 could be causing an over travel error in inches.
Can you post up a snippet of your program a few lines before and after line 22 where it’s finding an error. When I get in the office tomorrow I will back plot it and make sure the arcs are tangent and match up. Could be a minor rounding issue.
As for the clicking, I occasionally get this. I run the axis back and forth and hose some WD40 on the screw to flush off any chips. It normally goes away after a jog or two.
looks like that may have done the trick i changed my fusion program back to inches and regenerated the code and everything seems to be working flawlessly. Im guessing just like you said its most likely a rounding issue. as for the z I will give that a shot in the morning to hopefully get the clicking to go away. Thank you for the help !
I’ve found similar issues on the original Fusion post. It didn’t post the G code to set the machine to inch/mm at the beginning of the program. No way to change the mode manually, only what the DRO displays.
