We just got our Crossfire Pro up and running in the Ag Shop I run. I have been trying to work with an FFA logo file so that I can mix it in with other files. I got the file off of plasmaspider.com and it is a very clean looking file. The problem is that I can not get the fill gaps process to go through on Fusion 360 as the computer just spins. I belive it is because it is such a large file. Best I can tell from research is that it needs the segments converted to splined lines but I can not figure out how to do that.
I have cut exclusively closed cuts so far. I have several signs I’ll be trying soon which have a bunch of single lines.
One the single line cuts, any other tips for getting good, clean starts and stops? I saw in the video no lead-in/out, no pierce clearance, smoothing on, and compensation on center.
Is there anything else (F360 and/or machine settings wise) you can recommend be done to try for the cleanest single line cuts?
FFA is a great organization and that is a cool sign. I may try to pass it along to my local school corp FFA representative. Please post a picture if/when you get it cut out. Thank you.
I was able to recreate what you did and then apply to the USMC Logo that I had been working on for several weeks for a student that graduated last year.
Thank you, out of nine seniors in our little school we are sending 2 this year. I am going to post my marines picture in a minute. It turned out okay, but should have been cut larger I lost a few details.
I’ve been doing an easier method, in firecontrol if you just bring the torch high off your material (so it doesnt cut or burn anything), manually flick on the torch then back off (in firecontrol) and then start your cutting while your plasmas postflow is running. the initial pierce will operate properly because the post flow is still running.
That sounds like it would work well. Myself I like to minimize manual tasks that I have to remember to do at the table.
I already have an issue with 85 things going on in my brain at one time that I have to sort out all the time. lol
I like to add a small line or hole as the first operation then the long first pierce delay is defeated.
Then any time I run that program in the future it automatically purges and defeats the initial pierce delay with intervention. It just baked into the program.
