This time they may only want 50 of each and next time it could be 10-100, etc. I mostly would be working with either 3/16 or 1/4 for these. I currently have a full 4x8 sheet, but next time I may have a 1/2 used sheet available.
What would be the most efficient way to create these in software, define how many I need of each and the size of the material I have available and have the software ânestâ them for me so I can cut them out? Iâve watched a bunch of videos online but so far have not yet found a good example of doing this complete process.
At the moment I cannot run fusion 360 as my only computer that meets the requirements died a horrible death. I do have access to a linux laptop and an OLD windows 7 PC. Hoping to do a few of these jobs to make the money needed to purchase a new computer.
If they(your client) are the ones producing the shop drawings you posted, maybe you could have them send you a dxf instead of the pdf or paper copy.
If you have to produce the DXF and you are concerned about having enough power to run Fusion, I think i would use a simple 2d program like Qcad for your design⌠then use sheetcam for your cam.
Parts like this can be done directly in Sheetcam with the âshapesâ menu. You can select a rectangle with 4 holes, then specify the dimensions, hole size, spacing, radius, etc. Then duplicate and âarrayâ the parts on the sheet. Less than 5 minutes, once you learn the process.
