I ran into an issue when trying to create the cut path for a couple parts, specifically when selecting the contours for the plasma to cut. Fusion will not let me select the perimeter contour, instead I have to select every line. A workaround is to select to entire component and then select the gear and select outside loop since I don’t want the path to include the circles inside.
In that way it’ll chain select all the outer in inner contours and won’t leave you with many line segments to select which would cause a lot of stop and starts along your cut.
If you post your f3d I could run it through Fusion while live streaming on Twitch and show you exactly what I’m talking about.
