After using my Crossfire Pro for a while my VIM/THC box has failed (confirmed after diagnosis with Langmuir). I was using the divided 50:1 connection for THC but now I am looking to use RAW. Perhaps it is more reliable.
I will continue to use the CNC port to fire the torch.
For wiring the THC the insides of my plasma are as follows:
The green circle at top of image is the clamp connection. The RAW (+) can be connected there (?)
The purple circle at bottom of image is the torch connector. Do I simply put a ring connector around that thread for my RAW (-) (or is it necessary to tap into the black wires that surround the port?
Thanks for the assistance, hopefully I can give into the forum once I have some experience!
Thanks
