Getting check error when loading program (Solved)
Hello all,
I installed V24.1.6 yesterday and ran the machine all day.
Today I get a check error when I try to load any program in fire control??
Specific error; program check encountered an error in your program. Please correct this in your program before proceeding.
Error at line 149: G3 x3.2.0211 and so on.
The motion command has an invalid target. G2,G3< and G38.2 generates this error, if the ark is impossible to generate or if the probe target is the current position.
I suspected sheet cam but I get the same error even when I load a saved program that worked before.
I uninstalled both sheetcam and fire control and re-installed and get the same error…???
I also tried a different usb cable, also tunrned off all lead in and out and overcut. To no avail
I am stumped and stopped. Any insight to whats going on here?
I will revert to the previous version of fire control and see if that works.
Ended up being able to load the break in program. Ran it and now everything works again…
Son of a hockey puck
Weird! Glad you got it working. Thank you for reporting back.
