So, I’ve been using my pro and gyoertherm 45 so with machine torch for about 2 weeks now. I downloaded the tool file that someone was nice enough to put together and share.
Question 1 - air pressure
How often do you adjust the pressure? I don’t have a valve to adjust the air pressure. But can get one. Otherwise the compressor is just set for 125 psi.
Question 2 - Amps
Yep I find I always leave my plasma at 45 amps. I have adjusted it a few times testing things out. But my cuts are not good then. I’m usually cutting 16 or 18 gauge. Do you adjust yours often or use less for those gauges?
Question 3 - speeds
I find some of the programmed tools have the speeds at 350” min. That’s fast. Can this machine handle that? Is a lot accuracy lost?
I cannot for the life of me figure out my speeds and amps My cuts aren’t great. I have the water filter on the compressor and the one built into the plasma and I always drain the tank. I recently put new consumables on. The last set I just changed had about 675 piercings.
Try a cut at 30A, 60ipm and 75psi on that 16 or 18 gauge and see if it looks better. As I understand it, that cutting current and air pressure are way too high, likely making some sort of distorted plasma cone.
The Hypertherm cutter is self regulating for air pressure. The only thing you need to do is feed it the recommended pressure, which is 90-135psi with air flowing.
60IPM on 16 ga. steel is really slow, even at 30 amps. I generally cut 16 ga. at 30 amps and 150IPM.
Hypertherm cut charts are based on leaving the machine set at 45 amps. The Pro table has a max speed of 300IPM, so you need to stay below that speed.
I don’t have a Hypertherm and I run nozzles that are sized to run at the amperages that I use. You may need to turn yours down, because the recommended cut speed at 45 amps exceeds the max speed of the table.
