Fusion not finding CF machine
Hey guys, I’ve had my CF Pro for 3-4 years and used Fusion to design parts without issue. Last week I had to get a new computer and there is a glitch, when I go to manufacture, then cutting I can’t figure out how to get it to recognize my machine. probably a simple fix, but unsure.
I assume i will have similar issues with the MR-1??
You need to install the CrossFire post processor for Fusion. Look at Downloads | Langmuir Systems
Here is the guidance from Langmuir after you download that post processor file:
https://www.langmuirsystems.com/software/fusion#post-section
Also, make sure to export your tool library from the old computer and save it to the new one.
This way you don’t have to manually re-create your library again since you’re still running the same plasma cutter (assuming).
