The Crossfire controller is an Arduino clone running a custom version of GRBL 1.3ls. You can just type G-Code right into the controller using putty. See Grbl v1.1 Commands · gnea/grbl Wiki · GitHub
You can just do a incremental move at the end of your code.
G0 G91 Y1
https://linuxcnc.org/docs/html/gcode/g-code.html#gcode:g90-g91
check out camotics
Grbl is GPL right? I need to find the CD with the source code that came along with the Crossfire ![]()
Here is another idea to consider (all pierce delays are made the same with this post processor)
Unless something changed with this PP, that is just info to log on the tool setup. Cut speed IIRC is the only thing it pulls from that set.
Ill double check when i get back to the cutter.
