Got everything plugged in and ready to jog the table for the first time. But I cannot get Firecontrol to launch on my new Dell Intell i5 laptop. I uninstalled and re-installed several times. Nothing. Icon shows on the desktop, but doesn’t start the program.
Got home and downloaded Firecontrol on wife’s Dell laptop and it start’s right up!
Really need Firecontrol to run on MY laptop. Any ideas??
OK… I tried to delete this folder,but was prevented from doing so. Message appeared saying that the folder was in use. I even ran the “Task Manager” to see what was running and Firecontol is not on the list of running apps.
I uninstalled Firecontrol once again, deleted the “.firecontrol” folder, installed Firecontrol once again. Still will not start.
Getting frustrated…
I am being prevented from deleting the folder because it is being used by Firecontrol, yet Firecontrol is not even running, (according to Task Manager). I CAN delete this folder after Firecontol is uninstalled.
Do you see any Java programs running in your task Manager? If so try closing these first. Also, if you still can’t delete the folder try restarting your computer and trying again before opening FireControl.
I can delete the folder after restarting laptop. However, Firecontrol still not starting. Not even when trying to start as Admin. Folder re-appears and, again, cannot be deleted. Only app that shows in Task Manager is “Google Chrome”.
Looks like the process is running and thus not letting you delete its file. Definitely try to end task and delete the folder, then try re-opening. If that doesn’t work and you can access the files inside the .FireControl folder please email them to support@langmuirsystems.com
Doubtful the issue is related to your openGL drivers as its a new laptop so its likely not- but try making sure your drivers are up to date.
I have found that firecontrol doesn’t like to launch for me unless laptop has an internet connection. If by chance anyone has a similar issue, as soon as I used my phone as a hotspot I was able to launch firecontrol.
I have internet, and it opens on my other two computers. A couple things were brought up on the Facebook groups that I’m going to try tonight. I probably still have corrupt files and need to get rid of them all. I’ll post if it all works out and what I did to fix it.
