Finecut tips kerf width?
I use .060 kerf width for regular tips… Do you have to change kerf width in Cam program when using finecut tips ???
Yes, Fusion takes this input into consideration to figure out tool paths.
Small fine area cuts will be skipped over if the kerf is set to wide.
That’s the whole point of using fine cut consumables. They cut a smaller kerf, so you can cut smaller details.
The best thing to do is some test cuts and measure the actual kerf width. Cut a 1 or 2 inch square with outside offset and adjust your kerf width until the square is the correct size.
You should do this with your normal consumables too. .060" is probably wider than the actual kerf width.
