I’ve only been cutting carbon steel (11GA to 16GA) so far as I learn the ropes with random projects, making different designs in Fusion 360… still using the original consumables even though I bought a bunch of additional Hypertherm consumables for finecuts and etching.
On to my questions… Ultimately, I’m curious why I shouldn’t just buy and use the finecut consumables in the future for everything if it produces a better cut? Do the finecut consumables have a shorter life?
Why fine cuts? I cut 16 gauge on pro with Titanium 45 with plasmadyn machine torch at 45 amps, cut speed 205 ipm, cut height .059, 120 psi air supply to machine and 70 psi air at torch. I don’t lose any detail in cuts you can see the barbs on the barbwire pics clear as day no melt out. No THC on my pro either.
