Has anybody used the fine cut tips for razorweld 45. Have you changed the kerf width / feed rate / pierce delay / pierce height / plunge rate / cut height ? What settings have worked for you or are they the same as the regular tips ???
In the top right of this screen do a search for razor fine and you will finds lots of discussions on the topic.
