Completely my fault, was jogging z when I thought I was jogging x. Anyway, can the tip be replaced? and if not, how do I buy another probe? It seems that you can only order one through Langmuirs site if you buy an MR-1 to go along with it.
I forget what somebody said the thread was…but you get the idea. (or, submit a ticket to Langmuir to purchase)
I was told it was M3 thread? Ive been on the hunt for a 1mm tip but unable to find something that matches the length
You could put a 20mm extension on something like this…but you’re likely not going to find one with much length because of the shank flexing. 1mm ball has a tiny shank diameter, and you won’t have much clearance between it and the ball and risk probing with the shank and not the ball if you have a bur, or chips, or uneven edges.
M3 might be correct. I haven’t looked at it.
I’m just trying to have the ability to probe the lip on the smw vises for when I flip parts. Unless theres a better way that I’m unaware of. Just seems like the most accurate way to achieve desired thickness of parts
Oh right…I think I remember this conversation previously.
You could go with this guy, with the longer shank, and the adapter below, and an extension. Would be a little longer than the MR-1 but not by a lot.
https://www.mscdirect.com/browse/tn/tn?mscNew=true&searchterm=M2+1mm+stylus+&hdrsrh=true
M2 to M3 adapter
https://www.mscdirect.com/product/details/00553750
M3 10mm extension
https://www.mscdirect.com/product/details/00553784
I ran/programmed CMM for years, and did a lot of custom probe builds. lol
If you have a set of parallels you can flip The jaws on your SMW vice to the flat side and move your parallels around as needed for probing
Thanks all
