So you recommend this along with a motor guard?
You put this on the end of the air hose and plug it into the plasma cutter. These are the last line of defense for dirt and moisture.
" The advanced element in this product filters down to .85 microns, while still maintaining excellent air flow. When the element becomes completely saturated, it reduces air flow and will not allow you to spray to your desired PSI until the element is replaced. This is important in maintaining the quality of your airbrushing and to the longevity of your pneumatic tools. *Other products on the market allow you to operate your tools even after your filter has been depleted. Filter Element Replacement recommendation: 3 months for weekly use, one month for daily use an in line compressed air filter is an exceptional advancement in filters with its moisture and contaminant blocking element."
I just dry them out if they have moisture/water in them. I replace them when my air pressure drops 5psi after they are dried and cleaned.
I went ahead and ordered one with a spare filter as well. Last ditch I suppose before going and buying either a RAD, or a giant desiccant dryer tube.
Great tip George! Thanks.
