I am using sheetcam with my crossfire Pro. I have a series of shapes. It cuts the first one fine, then on every subsequent shape, it goes down to touch the metal and then errors out. It says something about pierce delay being too short, (It never even seems to try to ignite the torch) but it asks if I want to retry, and then I choose “Generate” to modify the code from that line.
Then it works for that current shape and fails on the next. Lather rinse repeat. I am not sure what it could be. Is there something in the post that behaves differently from the first shape to the later shapes? I appreciate any insight the team here can provide.
It will always work for the first cut, even if you set the delay to zero. I don’t know why, but Firecontrol makes the first delay longer than the rest.
The minimum recommended delay is .5 second, regardless of the plasma manufacturers recommendations.
Yes, I found the setting in the tool options and set it to .5 It actually seems long now for the thin material I am cutting, but I can experiment from here. Thank you again for the responses. Consider this thread done.
