Everlast 62i - torch moving before cutting voltage sensed
I use the terms equally. I am not certain but I believe that cooler is really meant for fluid and not air to run thru it so it is not designed for using the way most of us use it. A true air cooler unit would be more like a "heat exchanging unit like HVACs use to limit the loss of air temp when bringing in cold outside air in the winter.
I did another thing with my “after cooler/transmission cooler”: I set it at about a 45 degree angle. The air comes in at the top. At no point is there an upward turned leg that could trap any moisture.
I also have five self drain water collectors: three that I added at low points, one in the plasma cutter and one in the refrigerated drying unit. None of them have ever shown any moisture (don’t know if that is a good sign or a bad sign!) :man_shrugging:
Great stuff, thanks for sharing all the detail. So here’s what I’m thinking. I run a 3/4" maxline air system. I’ll integrate the aftercooler into that setup (likely after extending the run so it has more time to cool) and use the following fittings to connect the aftercooler to my Maxline system: https://cdn.zappy.app/5ff2e541f3eeef6efd8422c99a3b4262.png
So it will go from the tank, to 20-30ft run of maxline, through the aftercooler (which I’ll wall mount at a 45 degree angle, with a fan), then to a water trap, then it will integrate into my existing setup of filter, 1 gallon dessicant dryer, motor guard filter and then into the plasma.
Ill see how this was to remove water and then consider adding the harbor freight air dryer in the future.
Incorporate a few drip t’s with cutoff valves to catch moisture. You open the valves ever so often and bleed the line
I would put a coalescing filter before the desiccant as well.
@rjpowell9 all great advice in helping you get going. On the lighter side we are all like real ugly wives. We try to get as deep in your wallet as we can.:grin::rofl::sunglasses:
Now you’ve confused me. So you are saying pretty wives, like all of us married men have :wink:…won’t get into our wallets??? :rofl:
That’s one I can’t answer… Never experienced that one.:rofl:.
Ok so i removed all sharp objects from the house. I am safe for now.
OMG Philip! I gave you a lifeline and you just refuse to take it! :rofl:
I would tell what I tell her all the time but it might offend some.:grimacing:
She goes oh God you ugly. I married her when she was in great need of glasses
The wife to me today when I placed the Amazon order for all those parts “Does every one, like does every one have this problem with compressed air??”. Me back to the wife “Yes, all my buds in the forum, they all have the same problem, you should come see some of their ideas, it’s wild”. Her back to me “You lost me at buds in the forum” and then she walked away.
Oh my that’s funny!! Yes it was a true statement though. Just let her see the comments I made about my wife. Then she will be grateful.
four years ago she agreed to let me buy a harbor freight welder for $165 so that I could build an offset smoker. Fast forward to now, there is a 400 sq ft shop in the back yard with tens of thousands of money into it and still no offset smoker… surprised I’m not forced to sleep in said shop…
Old song new bird if you know what I mean. Hey at least I don’t have cold feet in my back.
Tell her we all talk about our wives here… she will log right on. :wink:
That fellas is how we maintain couch privileges.
I get in trouble when I try to sleep on the couch… especially in the wintertime. :wink:
Your wife is like mine wants you for your body😬 heat!
Perfect!!! I was hoping someone would bring us back on topic: “torch moving before cutting voltage sensed!” :crazy_face:
She tells me I’m hot all the time… all this time I thought it was my looks! :grimacing::stuck_out_tongue_winking_eye:
just an update, i got the parts in for the aftercooler and automatic tank drain valve, hoping to get it installed within the next couple days and retest my cuts (to see if I can eliminate the bevel).
My son’s travel baseball schedule has been crushing me, very little time to work in the shop.
