Ok I have a new issue. I have recently upgraded my air system and am back to trying to get my CFP to cut. The new issue is that my Machine torch will not fire at all. When I switch to my hand torch, it fires up just fine. All I’m trying to do is the Torch On/Off test right now
Settings:
Running CNC setting
78 psi
45 amps
tip and electrode are the same as hand torch (1.1mm tip and appropriate electrode)
I’m thinking that maybe a pin came out of the machine torch connection one of the times that I was pulling it out.
What pins should I have for the machine torch? Quick search tells me I should have Pins 1,2,4,&7. I have the 9 pin on both torches. On the hand torch i have 1, 2, 4, 7, and 9. The machine torch has 2, 4, 7, and 9.
This is all I can come up with as the difference in the setups.
I purchased the Hasweld torch from amazon and had to rewire it to get it to work. Using a pair of pliers I pulled pin one on the euro plug. then used a screwdriver and unscrewed the torch plug, I pulled the wire from the #1 slot and put it in the #2 position and reinstalled it. before doing this modification as soon as i turned the plasma arc on it would fire the torch, after the modification it works great. So my plug looks like the one on the right in the picture but the wire from pin #1 is in #2 slot and the wire that was in the #2 slot i tucked in to the handle.
