You have to gut the torch.
The only thing holding the Easyscriber in is the retaining cap.
Nothing else needed.
I have posted screenshots of my setup here
https://forum.langmuirsystems.com/t/easyscriber-sheetcam-settings/23889
General Info.
THC is turned off
Negative number in the Cut height (-0.1" works best) for AL
I have tried -0.1 and -0.15 on HR steel p&o and it only scratches the surface.
It is spring loaded and no difference in depth so you only have to get past the IHS for it to work. -
Make sure to choose shortest path in Cut path when setting up Operations in Sheetcam
Hope this helps
Would like to see what others can come up with.
