For the members on here using the Easy Scriber; How do you like it? Any tips or tricks I should be aware of? I’m using fusion CAD, CAM, & Post Processing. Any advice would be greatly appreciated.
Thanks
Travis
Tried for the first time, love it, Set the cut height to negative .05 and use an existing cut file. Turn off the plasma cutter and turn off height control.
If your using the easyscriber for art and not just normal lines you should read on setting up a milling tool to scribe lines. I played around with it for few hours but I’ve been so busy I haven’t did much with it.
