Inkscape for easy hatch fill design work.
I didn’t have that in the extensions I had to download it it is working real good now I will post a picture tomorrow.
Thanks for the help everyone.
Heres one i did a while ago
https://forum.langmuirsystems.com/uploads/db6772/original/3X/9/8/9849a872bb64e9d3044ac856ce317eae4b0e736e.jpeg
Maxxice, Would you care to share how you created the NC file?
I have the hatching almost the way I want it. Having trouble with the NC part.
I am using Fusion
Thanks
The hatching was done using inkscape
-0.8" for “cut height” will bottom out the Easy Scriber utilizing IHS with THC off. I recommend -0.6" cut height for 14 gauge mild steel sheet. I have also used this setting for aluminum valve covers to get a better etch. 4 passes will define it even better.
