Drilling using MR-1
Hello Group. I am needing to drill some holes for a 1/4-20 screw. The drill bit required is a #7 drill (.201)
What are your guys and gals using to drill number drills with. I dont think they make er20 collets for number drills…or do they.
Thanks,
Sam
.201" is just over 5mm, so you would use a 6mm collet. ER collets typically cover a 1mm range.
Options for ya:
  1. helical bore with an end mill. Optionally pre-drill a pilot hole with a stub drill
  2. use a metric collet. A 6-5 mm collet should work
7/32 ER20 collet is .219 and will close down to .201 just fine. You don’t need a metric collet (and a 6mm collet is .236, so you have to squeeze it more anyway).
I use a 13/64 (.203) drill bit in a 7/32 collet for 1/4 -20 threads. I use a thread mill to create the threads with a pitch diameter of .05 , pitch diameter offset of .0512 and multiple passes (6 passes, so I don’t stress the small thread mill). This formula worked perfect for the 1/4- cap head screws I had on hand. I did try a regular 1/4-20 bolt and the threads were a little loose. In my model I use a hole diameter of .203. I’m using fusion 360. Hope this helps
Awesome answers Yall. Thank you very much.
What threadmill size did you use for this ?
I use a Jacobs No 1A with a 1/2" arbor. You can find them on ebay fairly cheap.
I use the Langmuir 1/4 inch single flute thread mill.
What settings/steps did you use for this thread. We just setup our machine and did the exact same 1/4-20 with Single point thread mill and my threads didn’t turn out. I’m getting ready to try again and could use some help. I’m not used to single points.
You have to tell Fusion how many teeth are on the thread mill.
Is your hole the correct size for a 1/4-20 thread?
Sorry I read your question wrong.
Watch this video. Everything you need to know to get started.
If you used the steps I outlined above and found the results unsuccessful, I think watching the NY CNC video titled “Thread milling :The Ultimate Guide WW187” on YouTube might be helpful. This video really helped me understand how to set up the thread milling in Fusion 360. I never model the threads in my model, I just model a hole. Also when I say “passes” I mean stepovers.
