Drag Engraving Settings
Hi all,
I was wondering how everyone who uses the drag engraver on the crossfire pro is doing it. I have mine running such that it touches off initially at the start of a “cut” but maintains that “cut height” for the entire cut, i.e. no torch height control function. However, with this I find there are areas due to slight wave in the material where I am not in contact and barely get any engraved mark, if any. I don’t want to set it up to dig super deep at the start because I don’t want to risk damage to my torch (I am using an easy scribe with Hypertherm torch) so I am curious if anyone has a work around for this.
I generally am using the drag engraver as a layout marker for bend lines, center marks etc.
Thanks,
Whizbang
I had it running like that also. I have had it set up to touch off at some point. but I’ve forgotten how. I post back here if I find the info Cheers
