Was seeing if anyone has converted their table to downdraft? I might run 1 or 2 parts per week and filling and emptying the water is a pain.
Don’t drain it. When I had my pro I had a large piece of sheet metal with hems corners that fit over top of the whole water table for when it wasn’t in use.
It’s slowed down the evaporation quite a bit.
I might have only drained my pro 4 or 5 times in 3 years. Usually the only reason I would drain it is cuz it would be filled with metal and the weighed a thousand pounds.
Downdraft would probably be good too you would have to somehow stabilize the frame considering the pan is part of the frame.
X2 on this. The pan acts as the diaphragm holding everything square.
Could always bend up a 2-3 “straps” to span the Y-axis and bolt them to the front and back of the frame rails, such that they are in tension, and then the pan just rests atop them.
If I was going to do this conversion I would square the table and then tack down a sheet of 1/8-in material in place of the pan. Then set up the crossfire pro with the torch set low in the holder to cut out a pattern in the sheet for the downdraft. If you’re really tricky you could tack the sheet to the bottom side of the tubing giving yourself some more space
You have to make a frame for the downdraft setup anyway so that will take the place of the water pan. On a table that small it should be a simple setup.
