Hey everyone,
I’ve been using my pro for a couple months now and was wondering if anyone has figured out if there’s a way to eliminate the divot on the backside of the parts where the lead in/lead out is located?
I’m currently using a Hypertherm Powermax 600 paired with a duramax retrofit torch using fine cut consumables. The cut’s are pretty clean with the age of this machine but I can’t seem to find a way to eliminate that divot on the backside if it’s possible.
Sheetcam Settings:
Material: 14G steel
Consumable: Hypertherm finecut
Kerf: 0.055"
Feed rate: 125 IPM
Pierce delay: 0.6s
Pierce height: 0.09"
Plunge rate: 100 IPM
Cut height: 0.06"
Lead in: Arc @ 0.125"
Lead out: Arc @ 0.125"
I’d appreciate any suggestions that may work! Thanks
