Hey I appreciate it, that did the trick now I can set the parameters. Thanks
When you import a file with multiple layers into Sheetcam, either DXF or SVG, it keeps them as separate layers. You would have to set up an operation on each layer or move the layers you want to cut into a single layer. If you don’t want to cut any line or contour, you can move them to another layer and not cut that layer.
