Diagonally Cutting 31" long piece
I have a drawing I am trying to create which is 31 in Long. So I need to cut this diagonally across the table. How do you go about setting this up in Fusion360 so when you cut it on the table or load the g code it cuts it diagonally on the table?
In mach3 on the top you’ll see (MDI Alt2) click on it the MDI screen comes up look on the left about half way down you will see local system rotated put the degree you want press enter go back to Program run or press alt1 under the graph window click regen toolpath part will rotate. Keep doing it until you get it set right dry run till it’s right where you want it. Should be good to go.
@john543 Awesome!!! I figured it had to be done in Mach3, but wasn’t really sure… I’ll try it out this afternoon. Thank you!!!
You can also select the entire sketch in Fusion and right click there is a move rotate function and you can rotate 45 degrees.
