Cutting fluid container
Has anyone had any issues with their cutting fluid container springing a leak? Not sure if coincidence or not but this last week when it was too hot to be doing anything outside the home (including the shop), I made a quick run out to check on some stuff and found my cutting fluid leaking out of the bottom of the plastic container. Unfortunately I haven’t even ran the cutting fluid pump on this machine yet as I haven’t cut anything too demanding. Has anyone changed the container holding their fluid?
I still have the same container for about a 1.5 years now. It’s still fine. Find the leak and seal it up with a polyurethane sealant should do the trick.
