Hey all,
I’m coming from mostly HAAS machines and there’s something about the MR-1 that I’m not understanding. I just ran a very simple program to machine an aluminum block to 2.000" x 3.750" x .75". the part came out to 2.021" x 3.771". On a HAAS (or any other industrial machine I’ve used) I would go into the tool comp page and comp my tool -.0105. I would then rerun my finish contour pass and the part would be within spec.
I’d appreciate some advice here on how to comp a tool or otherwise put this part into spec.
Thank you,
Charlie
Definitely wouldn’t be a bad idea to check your ball screw comp in the software.
But with it being oversized the same amount in both X and Y axis I’d lean toward the tool is a bit undersized. As of yet we don’t have cutter comp in the control, but maybe in some future update it will be added. So your best course of action is to edit the program to compensate for now.
Not having comp is a major pain when working a thread mill out to size too.
Thanks to both of you. I did the ball screw comp and the x was spot on w the y being .006 out over 10". Now adjusted for and going to cut again and try.
BUMMER on the no cutter comp - first thing i was thinking was about thread milling. Hoping its included in the upcoming software release.
Yeah, pretty nuts that cutter compensation wasn’t a “must-have” feature for the initial release of CC. The workflow that I can see is creating a new tool in CAM with a smaller diameter then re-posting it and rerunning it. I keep hoping someone will save me and point out that it has been there all along…
Does anyone have any CAM work-around recommendations? The only way I can think of is re-generating the toolpath with a smaller tool diameter. Then re-posting, then getting on the controller, then re-uploading, then re-running. That would mean that I’d have to create a new tool for every size that I’d want to comp. So, that’s like 10 or so tool sizes for each endmill. Can we start a GO FUND ME to pay a software engineer to implement cutter compensation?
I don’t know about F360 or any other software but SolidCAM has a cutter compensation table that will result in the G code being compensated when its posted, for those really old industrial machines that don’t have it in the control.
I wouldn’t get my hopes up on Langmuir getting it into CC anytime soon. They seem to be reinventing the wheel with CC instead of implementing already developed control software. Perhaps someday CC will behave similar to an industrial control with already industry established input methods and layout.
