Hi all, I have cruised through some existing threads and didn’t quite find what I’m looking for so dropping this question here.
I have been helping my son with an art project and I have noticed when I cut in Sheetcam I get significantly worse parts. Cuts don’t complete 100%. It’s almost like the torch pulls up and starts moving off to the next cut before one is complete leaving about a 0.250" -piece section of the cut that’s uncut. The parts also have part of a pierce hole in them which is ugly…
I have attached the .tap file if anyone wants to take a look.
Here is the Jet Tool setup. I’m wondering if my lead-in being 0 and no lead-out is the issue?
increase the pierce delay to .8 to 1 sec, especially for 11 gauge. it’s most likely not cutting thru initially when it first starts. up the plunge rate to 75.
also no need for 2 separate operations. just do 1 using outside offset and sheetcam will automatically will sort out the inside/outside cuts.
Ok, Thanks @nicaDd I watched a tutorial on the youtube and the guy said you needed to designate inside and outside. ya don’t know what ya don’t know… I appreciate the tips!
some people do use a separate operation for inside cuts if they are going to slow down the cut for say like holes or something that needs a slower feed rate but normally just doing how i mentioned will do.
