I have very limited space in my garage. My plan is to cut the legs off of the Pro just under the water table. Connect the bottom of the legs with angle iron and use a host to lift it to the ceiling when not in use. When in use I would lower it onto my welding table (4x7) that will stay underneath it. My concern with reading the forum is that it can be tricky to get and keep the table square. For those have put wheels on theirs and moved it around, do you have issues with it getting out of square after you move it? My guess is that I will only use it 1-2 times a year so it won’t get moved a lot. Other option is to just pay someone to cut the parts and save the headache, but no fun in that.
That will work no problem- looking forward to seeing it.
