If you had to, can you cut and feed your material through the machine to finish? Like you need a one piece 8’ long… Call it a skidplate, that’s the only thing that comes to mind.
You can index if you can keep everything lined up! U will need to post info on the part and the more experienced members can help you. I believe that there are a couple that have done this. I could help you if it were on a CNC machining center. I do know that you will have to put a side stop and a location point on the part for the first and second index. I have not tried this on my table yet. Which table do you have? @Sacco I believe I have seen you on here before but not if you have posted the size of your table.
Some one smarter than me on this can help you!
There is a YouTube video that can help you, I watched it once…
At the top right corner. The magnafying glass. Click it and search Indexing. Lots of great info on what your asking.
My Pro gets here next month, 48x33 (hopefully). This feature was a “selling point” of another table, plasma cam maybe? So this is more of pre arrival question.
I’m going to save the oh I didn’t know I need air compressor till after I get it. Or the long vrs short lead screws.
The magnafying glass option, that in Fire control?
Thanks!
This is the way to do it!!! Research, Research, and asking questions before it gets there!! I keep forgetting about the magnifying glass to do a search. Yep! 48x33.
[quote=“Sacco, post:4, topic:13570”]
Thanks!
[/quote] Top right corner of the screen your on reading this.
I happened to watch the YT Video mentioned by Gene Sibley just yesterday, so it was easy to find. https://youtu.be/OmByODAlPGE.
