I have a razerweld 45 cnc with a machine torch. Does the program control the amperage or does the machine control the amperage?
Machine controls amps.
Amps are set on the plasma cutter.
The only thing that the control software can do to the plasma cutter, is turn the torch on and off.
Thanks , i seen there were sitting in the program and didn’t know for sure.
This post will give you a bit more understanding of the tool values and how they relate to the final g-code in post processing in Fusion 360:
