is there a program available. to install into the crossfire where i can cut out duct fittings?
there is nothimng you can install on the crossfire…you can load a program on your laptop to do duct work fitting and such…but then you will need to convert those files to a G-code file for the Crossfire to cut from…
the person I will ask for their input is @TinWhisperer …he is a sheet metal wizard and knows all about that stuff…
@Jarett Welcome to the forum
Like @toolboy said Any program you get for HVAC duct is also going to need to be run through the post processor of firecontrol before being used.
I ve laid out fittings mostly by hand in Fusion and use a few random programs for pipe branch’s. If you find any inexpensive or free HVAC program please let me know.
Here is a link to a few fittings i’ve posted
I recently upgraded to a XR so I could build more fittings with and table, the pro was a little small for HVAC.
