When I start my cut the gantry always moves 2" over, is there a setting so it starts to cut where I set the torch?
How do I setup so I can cut diagonally, is it in mach3 program?
If you have your gcode done and loaded in mach3 and you jog your torch to where you want to start your cut just zero x and y axis and it will start from there.
You can also rotate your part in mach3 to. Click on the MDI tab put 45 degrees into the the local system rotate box press enter then go back to the program run tab and hit regen toolpath under the part screen and it will rotate.
