Well that didnt take long! Anyways went to remove the tip but found that it was Loctited to the unit, yes Blue Loctite, anyone run into this. Also im missing the adjustment screws. Hopefully I didnt destroy anything inside the unit. So who sell the tips? What size rubby tip, and what thread size is the stem?
Thanks for the help.
Dave
Langmuir sells the tips you need. As long as the body is ok and the tip is the only damaged part, the unit should be ok. I dropped mine and purchased 3 replacements from them.
Thanks for the response, I’m sending my probe back to be repaired. I had to use a vise grip to break the locktite free and somthing is loose in the housing now.
Dave
