Coupler slip? Nope. Shaft snap... Damn
Did a bunch of programming early this morning came out to the shop, loaded a fresh sheet into the machine and started traveling to program origin.
I thought I was lucky never having a coupler slipping issue but then it looked like it was slipping.
I untightened it and tightened it a couple times and then I realized the end of the shaft had actually sheared off…
This is my x axis shaft.
IMG_20211021_120806
IMG_20211021_120804
Fixed back up and running.
I will order a replacement I just needed to get things cut now.
Nice looking TIG weld!
I sincerely second that! :smile: :tumbler_glass:
I have to agree. Excellent job … I think you have TIG welded just a bit?
Here’s a close up picture of what I believe is the inclusion that this break migrated from.
@Bigdaddy2166 @Cletus @RAM
Thank you and I wish I could take the credit.
My partner in the CNC game has a long history of prototype welding and is an absolute perfectionist. @wassink_welding on Instagram.
https://www.instagram.com/p/CUbSJrxpRPo/?utm_medium=copy_link
I can tig weld but I’m average,skills wise. don’t think I’ve ever TIG welded anything but stainless steel now that I’m thinking about it.
They got the part out their door the same day.
Just reaffirms in my mind this is the CNC company I am sticking with.
There’s definitely going to be an XR in my future.
Thanks @langmuir-aksel
Definitely a top shelf company. Have always done me right. I’d put that repaired lead screw on the wall. Really did a great job on that. Very impressive.
I had a lead screw break the same way about 1 year ago. Langmuir immediately sent me a replacement! Bravo Langmuir!
Since I just ordered a XR and dont have any plasma from them only there setup table. What caused the failure? was it a bearing that froze. Thanks John
Not a bearing, I believe there may have been a small inclusion in the material itself which cause it to snap clean to the shoulder of the shaft.
I run mostly high speed operations ( 250 - 300 ipm ) and the repeated change of direction puts a ton of force on this part.
The replacement part should be here today or tomorrow.
I have ran it several times since the repair and have had no problems.
Congrats! I hope to have one in my future too. They seem to have put a lot of thought and care into their product line while making it affordable.
Delivered.
Pretty well packed inside a x tube rail with caps on both ends.
Thanks guys.
@langmuirsystems @langmuir-aksel
The warranty system works even in Canada. :+1:t2:
Hoping for a langmuir sticker pack one day!
@langmuir-aksel @langmuirsystems
Maybe when I order my XR.
Got mine the same way!!! Talk about bullet proof shipping protection!!! Langmuir’s customer service is second to none.
I’m glad the replacement lead screw made it to you in one piece, please let me know if you need anything else!
