Coolant pump specs
I need to replace the coolant pump and can’t see any of the specs on the pump. Does anybody here know which type to get? Looks like a sump pump but how many GMP?
Langmuir will send you a pump. You will need a pump with a 3/4 garden hose thread for the discharge. The 3/4 to 3/8 hose adapter will screw on.
Acquaer Water Pump Amazon.com
Here is an example. I am sure the OEM pump will be surprisingly inexpensive.
I purchased a Harbor Freight small pond pump. Works great.
Good old Harbour freight…
