What gauge wire was used when you made up your plug? Thanks
I had a bunch of 14g left over from a trailer I wired front to back so I used it to make my CPC run.
Did you happen to have a pin out of the plug or did you go with your own pin locations? Just four pins are needed right? One for each the torch and clamp and the two purple trigger wires. I’ll order the parts to make up the plug soon. For now I’m gonna use separate wires for raw arc voltage and tapping into my trigger wires.
I’d really insist you get the CPC port upgrade for your machine. If you don’t, I couldn’t advise you. If you do, this is how you run your CPC pins…
If you don’t have a machine torch, you will also need to move a pin in the torch plug-end and zip tie the trigger.
The cpc port and divider board will come when I purchase the machine torch. I’ll have to get it then. For now I’ll be going this route. Thanks for the info.
