Compressor Aftercooler Bracket
Okay so I did that. Works great. Worried about the vibrations induced into the cooler and water separator by the compressor for the fittings and possible leaks. What other mitigations are you running after the separator before the plasma? I fear I might not be doing enough considering I’m in the swamp of Houston.
I also noticed you were able to plumb the new copper directly to your compressor outlet. What fitting allowed you to do that? Have you investigated any options of being able to run a braided -10AN flex line between the compressor and intercooler instead of hard lining it?
