You can also use the project tool in the sketch workspace to project a sketch that was made earlier in time to the current sketch. But the purple sketch lines created by the project tool are not editable in the current sketch.
You can copy and paste. Edit the sketch you want to move copy all the geometry then exit that sketch. Then edit the second sketch and paste the geometry there.
There is something that is either “fixed” or “constrained”. Others would be able to pinpoint it.
My work-around is to select the item you want to move, click on the box to “Create Copy”, then move. Now go back and select the original and delete it.
Why won’t you ever share your f3d? It will not give me access to your credit card…and if it does I won’t spend too much money at Home Depot. You will barely notice the first few purchases!!!
I then selected the original again and deleted. Now you can select the worm and move it where you want but remember to “Edit Sketch” to move. Bobby v5Chelan.f3d (564.8 KB)
You are likely to have some issues with that cut because it is a double line. It might work. If it doesn’t you might be best to trace on another sketch with a single line down the middle. This is common with SVG files.
Looks like you are getting a handle on it now. To clarify my earlier post what I meant was to use “CRTL C” to copy and “CRTL V” to paste in the main sketch. It also has to be in edit mode. Both have to be in edit mode.
