Do you have a cut chart in the user manual? I tried to look up the specs so I could get you a guess, but they don’t publish the output voltage in their specs.
Try searching the forum. Anything I say would just be a guess.
Edit: I did a quick search, there are a few users on here that use the 60i maybe ask one of them.
Thanks for sending this! Really helpful. Have you noticed good results by using their recommended pierce delay? Or is that something you adjust based on your own experience? For example, for Mild Steel for the A60i it mentions that .5in should have a 0.75 pierce delay. Do you typically follow the pierce delays on the chart? Thanks!
Your welcome. The chart will put you in the ballpark but some adjustments are needed to fine tune it. Pierce delays are very close but I’ve found the pierce height and cut height need to be lowered some to get the best cuts. I had issues with bevel and dross at .19 and lowering the torch some improved the cuts a lot. Once you get things dialed in it cuts really nice.
Does the amount of extrude in fusion 360 for the design alter how it is cut on the machine? Or is it ok to use the same amount of extrude no matter the thickness of metal being cut?
It is leaving that geometry out because it is too small to cut when it calculates the lead in, kerf width ect. You would need to scale this up or change the design a bit.
See explanation below.
