Does anyone know if there is a CAD model of the Crossfire Pro that can be used for reference when making models? I can make my own rough one but figured why invest the time if one already exists.
I checked all the sites I could think of and didn’t find anything.
I was thinking the same thing mostly so I can get a head start on building a support shelf/caster system. It would be nice at the very least to have the exact dimensions of the four legs. I’m sure other ideas will come up as I browse the forums and wait for delivery as well.
I built a roller frame with casters on it, welded plates to the four table legs with adjustable bolts to level crossfire pro table on roller frame. The leg bolts float on roller frame sitting inside square tubing so table doesn’t slide off roller frame. Don’t have to worry about the crossfire pro table racking when roll unit around.
I like the frame and casters but I’m really interested in the storage tank and pump. Where did you find that? I’ve been looking and I can’t find a low profile. I know you have the pro which can be smaller than what’s needed for the XR.
yea I didn’t want to alter the machine anymore than I had to. I sits in the lower table/shelf and i’m using 4" spacers inside the legs to get the height up.
I wonder if they changed the size since you got yours? These are the measurements from the site. They don’t have the short side leg to leg dimension but the long way is a lot different than yours.
Pretty sure the measurements you are seeing online are over all outside dimensions and not leg to leg. Went down and re measured this morning to confirm and mine is what I posted above.
I fought with it also. I waited on mine until I had the table. I did have most everything else ready and waiting for its arrival. Didn’t want to have the shelf welded then have to cut back up cause my dummy self measured wrong or something. But theres no way I would have it without casters and the shelf.
